Pass Boolean through FS dialog
CAD_SSPCAD_SSP Member Posts: 45 ✭✭
At present you cannot pass a boolean through a feature script dialog, this is ideal if you want to hide a feature in certain configurations (rather than forcing them to fail which seems an odd workaround to me).
Something like:
<span style="background-color: transparent; color: inherit; font-size: inherit; white-space: pre-wrap;">annotation { "Name" : "My Boolean Variable" }
</span><span style="background-color: transparent; color: inherit; font-size: inherit; white-space: pre-wrap;">definition.myBooleanVariable is booleanVariable;</span>
A current workaround is to pass the variable name in as a string (without "#") and then check if it is a boolean and so on but is not very intuitive as you want to include the "#" but that stops it working.
  • mahirmahir Member, Developers Posts: 1,314 ✭✭✭✭✭
    I'm not sure I understand this request. FeatureScripts can defintely use boolean inputs. They look like checkboxes.
    annotation { "Name" : "My Boolean" }
            definition.myBoolean is boolean;
  • CAD_SSPCAD_SSP Member Posts: 45 ✭✭
    edited January 2018
    @mahir what I am trying to achieve is this:
    If your partstudio contains a variable that is a boolean such as "#Showitem = false" you cannot pass this boolean value into featurescript (as far as I can see).
    A boolean input as you state is a checkbox, you cannot assign a variable value or a formula to it.
    The only workaround I have found is to us a string query and pass the boolean name in as text, then you can use the use "getVariable" within FS to check the value i.e.
    <div>annotation { "Name" : "Hide If:" }
    definition.hideIf is string;</div>
    pass in "Showitem" without the "#" and then do a check to see what if anything was passed in:
    <div>var hideIfcheck is boolean = false;
    <span>if (definition.hideIf != "")
    </span>{
        try&nbsp;
            if (getVariable(context, definition.hideIf))
                     hideIfcheck = true;
        catch (error)
            reportFeatureWarning(context, id, "you have used a non Boolean or non-existant variable");
    }</div>
    This is a messy workaround as you instinctively want to put the variable name when you type it with the "#" but I cannot find a way of removing that within featurescript.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,844
    edited January 2018
    Have you tried isAnything? That will take a variable as input.
    edited January 2018
    isAnything(definition.myBoolean)
    A code snippet for Neil's suggestion:
    annotation { "Feature Type Name" : "Take Boolean" }
    export const takeBoolean = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Boolean" }
            isAnything(definition.bool);
                if (!(definition.bool is boolean))
                    throw regenError("Boolean should be a boolean", ["bool"]);
    But you may want to consider just using a normal checkbox for your feature and then using configurations to toggle it rather than variables:
    https://www.onshape.com/videos/introducing-onshape-configurations
    edited January 2018
    That's what I was thinking. Here's an example of configuring the Unsupressed property of a feature, which seems to be exactly what you'd like to do. In this case I used a list input to control suppression state of the circle and square, but I used checkbox inputs to independently control the suppression state of the triangle and pentagon.
    https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/b02ec721136c6121c1a02cc1
    Thanks, isAnything is exactly what I want.
    Configurations are perfect for most applications but don't suit this particular case.
