Variables in Configuration
turan_aydin
Member Posts: 16 ✭✭
Hello,
Is there any "trick" to assign Variables to the values in Configuration table or this is not implemented yet?
I think @turan_aydin wanted to use variable in configuration table as value.
About configuration variables, I'm currently facing the follwing issue :
With reference to this document (part studio 1 _ version B2_janv2018) : https://cad.onshape.com/documents/9181221e67016abc6e611600/w/1177aed0fb69afc9f9fdb1bf/e/5d9c264a121f1f416843aa28
in the linear pattern 2 feature, the instance account is set with the '#nbr_ventaux' variable; this variable is defined in the configuration variables.
Graphically, this linear pattern works correctly when the variable is set to less than 5; then, when it is greater than 4, only 4 instances are displayed.
I cannot figure out if it is an issue related to the variable or a video generation issue ?
Would you have any hints about that kind of issue ?
Many thanks
And I want to define it as L = 100 , H=L/2 , D=H/2
If the variables H and D only depend on length, they do not need to be configured.
Here's an example accomplishing what I think you're saying:
https://cad.onshape.com/documents/d8bfc777e7f46fc2f1a4be67/w/da2603b8d1603199cf48b5cd/e/de8b269801e1f03af5b61a39
O.S.
Something like this? and as @owen_sparks points out, the video shows a nice conditional formula.
Probably so, for some reason OP had difficulties on performing that..
