Insert into Drawings
in Drawings
Could anyone give a little advice please. I would like to insert part of an assembly into a drawing at a stage prior to its completion to help in its construction. I have tried hiding certain parts in the the part studio (Constructed top down ) however when inserted into a drawing this I still see the assembly with the hidden parts I have thought about exporting the file then importing back as I would for exploding then deleting the parts as required, but would this effect the original part studio. Any help would be appreciated thanks Regards Brian.
https://learn.onshape.com/learn/dashboard?labels=["Knowledge Base"]&values=["Technical Briefings"]
You'll need to set up a "named view" in the part studio, and then you can use that in the drawing.
Cheers,
Named view.
Dead easy
