Spline on a shaft
Member Posts: 3 EDU
I've been trying to create a spline on a shaft by drawing the end shape of the spline on the face of the shaft, removing it using the extrude command, patterning the extrude then using the boolean operation to subtract one from the other. As you can imagine, it fails! What's the easiest way to achieve this please?
