Dimensions in Assembly's
tristan_flintofftristan_flintoff Member Posts: 12 PRO
Is it possible to place a visual dimension in an assembly between two different assembly's that have been inserted?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,417
    No, but if those assemblies are mated with an offset, clicking the mate in the instance list will show the dimension on screen.
    I have clicked on the mate in the instance list as the below print screen but no measurements are showing up. Am i selecting the wrong thing?
    Sorry, that was a bit misleading - that only works with slider and cylindrical mates.
    @NeilCooke ;No Problem. Thanks for your help!
