Is there a way to assign a different color to a face on a part?
It appears that with a part, I have to create a new part to assign a different color to it. Coming from Inventor, you can assign a different color(s) to a face(s) within the same part. Is there a way inside Onshape to accomplish the same thing? Thank you!
NeilCooke Moderator, Onshape Employees Posts: 5,864
No, but there is an improvement request you can vote on ——>Senior Director, Technical Services, EMEA10
One workaround is to offset the face a small amount and change color of offset surface.
The improvement request to vote on is here 'Coloring faces'.
