Sheet metal bug?
Hi. Trying to make a simple sheet metal and it is ripping/cutting the sheet metal along lines never specified.
Step one: Made a sketch
Step two: Created surface from sketch (offset surface)
Note: I have selected said sketch using the feature tree and not by clicking on a sketch face.
-Noticed that said surface has undesired lines already splitting the surface
Step three: Created sheet metal, and sheet metal is ripped/cut along said lines
I had the same problem using the "fill" command from a sketch.
