Is there an alternative to Alt+Drag on Linux?
On every Linux desktop environment I have used, Alt+Drag moves the window under the mouse. The browser being another window, moves as well, so I can not use this key combination under Linux. Is there any alternative keys, or any plans to switch this over to something else when under Linux?
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
Aras said:JakeRamsley said:Hi Aras,
Can you clarify what you are trying to do? I can't think of any drag operations that we have that are modified by the ALT key.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1
http://www.spiked3.com
