Is there an alternative to Alt+Drag on Linux?
aras
Member Posts: 16 ✭✭
On every Linux desktop environment I have used, Alt+Drag moves the window under the mouse. The browser being another window, moves as well, so I can not use this key combination under Linux. Is there any alternative keys, or any plans to switch this over to something else when under Linux?
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Box/cross-select is done by simply clicking in free space and dragging. If the user drags left to right, the selection will be a box-select and will select entities that are fully encompassed in the area selecting. If the user drags right to left will do a cross-select and will select entities that partially fall into the area selecting. There should be no need for the ALT key.Aras said:
I believe OnShape uses Alt-Drag to do rectangle selection.JakeRamsley said:Hi Aras,
Can you clarify what you are trying to do? I can't think of any drag operations that we have that are modified by the ALT key.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1
http://www.spiked3.com
