I cant set material properties on .step parts I imported
reyhan_mujezinovic
Member Posts: 4 ✭
1 I import step files
2 I assign material to parts
3 Mass property says : one or more parts do not have material defined !!
For my project it is kind important to define mass to parts and assemblies.
did anyone had this issue? Any advice,
if I assign material to all parts or one by one it makes no difference,
Mass property still says some parts are not assigned and it is not like it missed just few parts, often it says mass=0
Can you post the URL of a public document with an example of this happening?
When I add same files on my account no problem... but in this private folder scenario I can't make it work
a) Switch to Pro Account or
b) Copy the private document (if you got the rights) to your Free Account. Now you can edit, but the document is public!
