Never used this before coming from AutoCad and don't understand how onshape works.
in Drawings
Like is there anyway to make it so like in AutoCad it only shows can place a 45 or 90 degree angle if you click the symbol in the bottom right and is there a way to see how long a line is while i'm drawing it. I'm trying to use this as a cad for when i'm not using a actual computer and im stuck to a school chromebook.
I suggest to check out the video library and also the learning center: https://learn.onshape.com/learn
Start out slow and be open to new ideas, but you luckily have found one of the best programs to learn with. Good luck and be vocal on the forums if you have any troubles or confusion. There are many great people just drooling on themselves to help
Request a video tutorial here.
