Flip Sheet Metal Extrude Thickness separately on parts
mike_hölscher
Member Posts: 110 ✭✭✭✭
I just found I can use a single Sheet Metal Model feature to create multiple sheet metal parts at once Nice.
I wanted to use the Sheet Metal Model Extrude to convert multiple sets of lines to multiple bend sheet metal parts.
But I could only flip the Thickness direction of all the lines at once using the dialog. I needed to flip only a certain set of lines in the sketch.
So I ended up making a separate Sheet Metal Model feature for this set of lines.
Maybe it is possible to toggle the thickness direction visually on each new sheet metal part separately by clicking a thickness direction arrow in the modelling area?
