Trying to solid impression this drawing
mark_cunninghammark_cunningham Member Posts: 78 ✭✭
edited February 2018 in Drawings
I'm trying to figure out how to impression indent these numbers and dot to dot finalize but i forget how to finalize curvations. also I cant seem to keep an oval in the 6 here. Help is appreciated.https://cad.onshape.com/documents/6b8c218c0fb417b74ebc58ea/w/4543d20f2652d7272b1e5b29/e/dcfd5bbfd54b8475d51f0f5b
Here is the original:https://cad.onshape.com/documents/7494c4e456a7f3f2f67fec23/w/c0837a29816b35600ba6d1cd/e/46de9968e003b1fba4aa9cb2
  • mahirmahir Member, Developers Posts: 1,317 ✭✭✭✭✭
    Not sure what you're trying to accomplish. What do you mean by "finalize curvations"?
    And what do you mean by keeping an oval in the 6? When I looked at your model, there is an oval in the 6. It's a different part since there is no attachment to the rest of the model, but it's there.
    Did you already solve your issues after posting? Looks fine to me.
  • mark_cunninghammark_cunningham Member Posts: 78 ✭✭
    Lana Saved the day! How did you do it Lana?!
    @mark_cunningham
    At the top of her document you should see a 'Make a copy' button.  Press that to get a copy of her document, and then you can explore the inputs she used into the two extrude features.
    From the current state of your document, what you'll need to do is:
    1. Flip the direction of your extrude so it is extruding up instead of down.  This can be accomplished by clicking on the manipulator arrow in the graphics area, or by pressing the button that looks like two arrows next to the extrude distance.
    2. Start another extrude; for this extrude, you'll want to select the inside of the letters.  To do this, you can click on them in the graphics area (don't click on 'sketch 1' in the feature tree).  The sketch will need to be visible for you to make selections from it.  If 'sketch 1' is greyed out in the feature tree, hover over it and click on the crossed-out eye to show the sketch.  If it is too hard to make the selections because the existing part is in the way, you can similarly hide the existing part by clicking the eye next to 'Part 1' in the parts list.
    3. Make sure that the second extrude is set to 'Add' and that either the 'merge with all' option is set, or the 'merge scope' is set to 'Part 1'.
    edit: As usual, there are a bunch of ways to do what you want, and Lana did it slightly differently than I described.  It may be interesting for you to look at both ways and see which makes more sense to you.
