Extrusions on Parts studio item do not stay located when the item is inserted into an asssembly.
phil_joyce
Member Posts: 13 PRO
When I move the part studio I have inserted into an assembly, some of the extrusions become dislocated. (If I fix them, it fixes the whole part studio in place.) What am I missing?
See Assembly 1 in my 'Integrating Sphere Support' drawing. The dowel pegs are not staying with the Retainer, (the part embossed 244-18041). Similarly, with the 'C Frame Vertical' extrusions.
Jake_Rosenfeld
@phil_joyce If you want your parts to be locked to each other in an assembly, you can use the 'group' mate:
https://cad.onshape.com/help/Content/mategroup.htm
The underlying problem here is that your extruded material is not actually connected to the base part. For example, in "C Frame Vertical" part studio, try using "Add" option in "Extrude 2" rather than "New". This way, your extrude will add material to "Part 1" rather than creating two entirely separate parts. Another option is to use the "Boolean" feature at the end to connect it all up.
https://cad.onshape.com/help/Content/extrude.htm
https://cad.onshape.com/help/Content/booleanparts.htm
Jake Rosenfeld - Modeling Team5 -
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi @phil_joyce
Not quite sure I understand the question...
A couple of tips though for getting quick forum help. (There's loads of helpful folks here but what is an obvious intent by the poster is often too vague if you see the project with fresh eyes.)
(1) Post a link to your document (just cut n paste from your browser address).
(2) All your parts are called "Part1" so when we talk about the "retainer" what's what?
(3) A screen grab with some mark ups would get us all on the same page.
Cheers,
OwS
HWM-Water Ltd5 -
NeilCooke
Moderator, Onshape Employees Posts: 5,932
Chances are it is somebody whose first name begins with P and they are browsing your document.
Senior Director, Technical Services, EMEA5
https://learn.onshape.com/courses/fundamentals-multi-part-part-studios
A lot of the parts in your Document look like they are geometrically related, and could be easier to build in one Part Studio.
Thank you very much for the links. The 'Boolean' in particular.
Cheers,
OwS
Text Extrusion:
Inserted into Assembly: Dowel pegs not attached, but the text extrusion stays put. There appears to be no difference in the extrusion settings other than direction.
I do remember Onshape prompting me to create a version in some of the work I've been doing, but I cannot remember what brought up that prompt, nor was I aware of any drawing status change as a result. I have certainly clicked on an update icon, but obviously not in the drawings in question.
OK, so I will go away and learn about version control. Thank you for your reply.
A small aside: What does the coloured 'P' that appears against some of my files, seemingly temporarily and at random, mean?
