Modeling Finish Stock (Cutting prior to machining)
kent_henderson
Member Posts: 70 PRO
We cut a lot of parts from plate that get turned in a lathe or otherwise machined. Is there an easy way create in a model, and on the subsequent drawing, the finish stock required? We pull parts studio parts directly from OnShape directly in to our nesting software so I need a modeled part I can nest. Take a look at the shared file, it's a couple simple flanges. I've modeled the (2) flanges. Then I modeled a third part to represent my burn-outs as shown on sheet2 of the drawing. My visual preference on the drawing is a phantom line representing the burn-out or material to be removed but of course still need something I can pull into Sigmanest. What I'm doing works but seems cumbersome. I wondering if there's an easier way.
https://cad.onshape.com/documents/8f3480dc07fd47ed307aef0c/w/2cb077e97aa3d803a522b57d/e/7a969ca11d8162f85138e469
Thanks in advance for any thoughts/advise,
Kent
Kent
John_P_Desilets
Onshape Employees, csevp Posts: 271
^^ I agree with @mahir Using a configuration for the stock size would be helpful. I made a quick example to show you. Below is the link .
https://cad.onshape.com/documents/9f730b0cdb8b51ca71fd5b75/w/ae7789b3d0dbcd0e86990370/e/459ae6562bf470a4ef8b7d3c
5
https://cad.onshape.com/documents/72e167d4f62ee42caae9fafd/w/4bac3a02de6537f931d939c6/e/91d5d8f7e3c795c06f3914ba
1. Derive finished machined part into another Part Studio
2. Add material to the part in reverse machining order (i.e. last machined face should be first material add operation)
3. Repeat until full blank achieved
4. Use configurations to suppress each of those features in order
5. Create a drawing showing each machining operation if you so desire!
@ilya_baran's method sound a little less hokey.
It isn't a big deal though. I think it only comes up when using different profiles to generate the base feature of a part. I don't think that's a common occurrence. You can easily overbuild the part and then cut away what you don't want instead.
