Is it possible to extrude around an irregular surface / solid in ONSHAPE?
martin_schyns
Member Posts: 2 ✭
I am drawing up a test gauge for a 3D printing environment. The gauge features a number of moving conical inserts which are printed with different tolerances. This allows the surface precision performance of the 3D printer to be assessed.
I have tried using Boolean operators; in an attempt to subtract the overlaps - but have not made any progress.
The surfaces to create the receiving holes for the test cones have been created using the REVOLVE function and then the CIRCULAR pattern tool.
That said, if you post a link to a public document, the problem is usually solved in minutes!
Linky
Owen S
