Workflow/Feature for extruding wrapped curves, with new, add/remove to/from a part options?
I am trying to find a more efficient workflow for adding/removing wrapped curves from a part. This is for creating cam slots, holes, protrusions, logos and other features in parts. I just finished a part that required 46 features to complete only the wrapped features.
Currently I do the following...
This is something that was simple in SW.
- Wrap the sketch geometry to the surface using the Sketch Wrapper FS.
- Fill the resulting curves with a surface.
- Thicken the resulting surfaces with the Remove option.
- Many curves requires running the Fill feature on each curve separately or you get a "Cannot create fill surface between multiple loops" error.
- Concentric curves requires creating individual thickened curves as tools, boolean subtracting the inner parts from the outer, then subtracting the resulting outer from the target part.
https://cad.onshape.com/documents/0bb13c1b6ed6d4a6dd75cf99/w/b4493d47a45c27ce485c84b9/e/c8050a35a7417c12b801bd40
