Mirror Boolean result
in General
Hello all,
I want to use the result of a Boolean in mirror to not redo all the steps. I want also use it with a rotation pattern.
But the thing is I can not use mirror feature, any idea how to get it ?
I want to place the down left boolean in where there is the orange cercle :
Thank.
Thank.
A more efficient way to do this would be to use extrude/remove to make the hole, then face mirror or face pattern (they are in the pull-down menu at the top of the mirror or pattern dialog).
Here is the link : https://cad.onshape.com/documents/cb30ada01f12293395bad0af/w/fbfaa6084b1dcdfa19bb4d2d/e/564e805f909a913773baff1d
I want to turn Hole Capt
https://cad.onshape.com/documents/928a0cb864141b9c748af1d2/w/ab93c50207b64bd02175c80c/e/4a2307d84e9b5599f39de4ae
Question still : How the import works ? because you imported the part I want to use in boolean and it was place where I derived + transform it.
So does the import find the part in the PartStudio ?
EDIT : Ok I get my answer myself. The derived function import the part in the partstudio.
