What mates should I use for a Reuleaux triangle rotation?
john_hackington
Member Posts: 43 ✭✭
Hi,
What mates should I use to get the Reuleaux triangle to rotate within the square in this assembly?
https://cad.onshape.com/documents/c7076af1b7a1f5c3cad9aa33/w/328860a966179beb4ec367d4/e/723a794413f54436d42a9000
An illustration of how the rotation should look like:
https://commons.wikimedia.org/wiki/File:Reuleaux_triangle_Animation.gif
Thank you!
Thank you!
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
This is very similar to a Wankel engine - very easy to do.
You will need;
an eccentric cam
2 revolute mates
1 mate relation
Philip Thomas - Onshape5 -
john_hackington
Member Posts: 43 ✭✭
Hi Philip,
Thanks for the cue! I'm able to successfully get the rotation with what you've suggested
Wondering though, do you think it's possible to get the same rotation without adding a physical external cam?
@philip_thomas1 -
MBartlett21
Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
@john_hackington
@philip_thomas
I have made an example showing it using two tangent mates:
https://cad.onshape.com/documents/6837f48dc8d88fe44c98ed6c/w/edf8e3d61121b32e22b73ef6/e/94fe1bf6544bf4b399de5df3
Just make sure you rotate the triangle slowly otherwise it goes wonky.6 -
NeilCooke
Moderator, Onshape Employees Posts: 5,926
@john_hackington if you don't want to use physical cams, use a sketch! https://cad.onshape.com/documents/825620768ae3a5beefc53dc9/w/e8a5d084cdc07c1cee0e63fc/e/f60a9dbb830285433efcaa50
Senior Director, Technical Services, EMEA2
You will need;
an eccentric cam
2 revolute mates
1 mate relation
@philip_thomas
@philip_thomas
@mbartlett21 - tangent mates are awesome, but they are also very finicky (in any cad system) - wherever there is more than one solution, or a singularity (eg tool in a corner touching two faces its supposed to be tangent to), then they tend to become unpredictable or 'stuck'.
Johns solution is far more robust and mimics the driving mechanics of the mechanism.
Be like John
On further thought of eliminating the physical external cam, I realize that the cam being "physical" is all a matter of my own perception. I could easily just hide the external cam and it would just be an invisible implicit rule of how my actual physical part should move.
@mbartlett21 - Thanks for looking into the problem and trying to devise an alternative solution! I did consider using tangent mates too, but besides the wonkiness of the resultant mechanism, the Reuleaux triangle would also no longer be an object of constant width if we fillet the edges.
BTW, even if you hide the part in the assembly, it will still show up in any drawing that you do of the assembly.
You're right indeed! I did a quick search and it seems to be an improvement item that they're working on. Hopefully there'll be a function in the near future for it.
https://forum.onshape.com/discussion/6956/part-visibility-in-assembly-drawings-for-illustrating-assembly-steps
https://learn.onshape.com/learn/article/branching-to-control-part-visibility
But suppressing the parts will make the mates not work.
What are you trying to do?
Wow! Thanks Neil, this is so elegant, it's very much just what I was looking for! I'm utterly delighted in all the capabilities that I continually uncover from Onshape
Don't worry, @NeilCooke answered it in his post above (https://forum.onshape.com/discussion/comment/37486/#Comment_37486)
The reuleaux triangle intersects the outside at some points.
