Removing area between spokes on a flywheel
I need input on how to pattern the cutout on this flywheel so as to make 6 spokes 60° apart.
https://cad.onshape.com/documents/fe2afb5f55cf42489278c204/w/9b61b5b5367d48cb90f9cdf2/e/afb05abda9724f4793070458
I've been approaching this sort of part design roughly the way it would be machined from solid, but perhaps that is not the best way to go with OnShape. In any case, the area between two adjacent spokes has been Extrude Removed and I was assuming that the extrude cut could be patterned around the rest of the flywheel but that's not working for me. Am I missing something in patterning a feature around a part, should it be approached differently or is this just not possible in OnShape yet?
Mike
Mike
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
You could extrude the pie shape as a New Solid, then Circular Pattern it to make six total (parts), then use those parts as tools to subtract from the base part using Boolean
Seems to work OK
https://cad.onshape.com/documents/8ba12d46bf7c4ab097363abf/w/dea81926c8424bf2a3237447
5 -
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
Michael3424 said:If OnS is listening, are there any plans to add patterns to sketches?Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
@Michael3424
In this specific scenario, the method I shared is definitely a workaround pending sketch patterns becoming available, but it's a technique which in some contexts would be valuable to know.
BTW, if I modelled the flywheel I would personally use a revolve; that way a single sketch and a single feature would replace your first four of each.5
Seems to work OK
Mike
mike
Mike
It did not work because the faces which need to be patterned are not specific to an individual spoke, but shared; they extend right around the model. This is a limitation of "Face" patterns which I had discovered in another connection and raised a ticket accordingly.
