Improvements to Onshape - March 2nd, 2018
NeilCooke
Moderator, Onshape Employees Posts: 5,965
With so many great new feature requests, the updates can't come fast enough! So here's the latest, ahead of schedule, with several new productivity features for Sheet Metal, Drawings and Configurations. Keep those improvement requests coming. Enjoy!
FACE PATTERN AND FACE MIRROR IN SHEET METAL
Face Pattern and Face Mirror features can now be added to active sheet metal parts. A new button has also been added to these feature dialogs to enable quick access to the Create Selection tool.ARC CENTERLINES IN DRAWINGS
The Edge to Edge Centerline feature in Drawings can now be used to add arc and circle centerlines, ideal for annotating arc slots and other curved features.SKETCHES IN DRAWING VIEWS
You can now add a sketch into an existing drawing view of a part. This gives you more ways to detail and annotate important information that is critical to the manufacture of your part.SPLINES IN DRAWINGS
You can now draw splines in Drawings. A spline can be drawn on the drawing sheet or it can be snapped to model geometry in a single drawing view (in which case it will be associated with the view). The spline entity has the same behavior as a spline in a sketch; you can make an open spline, a closed spline, move spline points to change the shape, add more spline points, and delete spline points. Splines in Drawings can also self-intersect.
DRAWING SHEET REFERENCES
The Drawing Sheets flyout now lists the Part, Part Studio or Assembly that the Drawing View was created from. Right-clicking the reference enables you to quickly switch tabs.
ADDING DATA TO CONFIGURATION TABLES
You can now copy and paste data into cells in a configuration table. These cells also now behave more like a spreadsheet with easy to use keyboard navigation.COMPARING CONFIGURATIONS
The Compare tool can now be used to inspect the differences between two configurations.CONFIGURE CUSTOM PROPERTIES
In addition to the default part properties, any custom part properties created by a Company admin can now be added to a configuration table.
SPLIT FACE WITH FACE OR SKETCH REGION
In the last update, we introduced the option to split a part using a face from a solid or a sketch region. This capability has now been extended to the Split Face feature. This gives you more flexibility; you no longer have to create a plane, a surface or a sketch perpendicular to the face you want to split.
10
CAD Engineering Manager
Sketches in drawings.. that are actually attached to views... Sweet!
Thank you
When will we be able to insert sketches that are in assemblies??
He descubierto que al asegurarme de mantener mis estudios de piezas tan simples como sea posible, realmente me ayuda con el rendimiento. Según mi experiencia, el rendimiento comienza a disminuir cuando se obtienen más de 100 funciones en un estudio de una sola pieza y REALMENTE se ralentiza después de 200 funciones. Ni siquiera me preguntes después de 300 características;). He tenido que entrenarme para ser disciplinado sobre el tamaño y complejidad del estudio en parte. Ahora uso mucho en contexto y trato de eliminarlos de mi ensamblaje de nivel superior, solo para mantener las referencias fáciles de administrar.
Llevo 244 features. Entiendo que pueda ralentizarse un poco, pero lo que no es nornal es que tarde más de 15 min sólo en mostrarme un sketch y otors 10 min en poder borrar un punto. No es normal. De esas 244 features se podrían bajar a 150 si no fuese tan lento, pero a veces opto por hacer features nuevas en vez de modificar las ya existentes porque tarda 15 min cada vez que intento modificar algo ya creado. Si esto es normal me buscaré otro programa con el que se pueda trabajar cómodamente.
btw, when can we meet the native BOM tool?
Por lo que comentas es posible que se deba a alguna operación específica que esté penalizando demasiado al rendimiento. Seguramente con una ligera modificación o cambio de la metodología de modelado se solucione.
Puedes comprobar los tiempos de regeneración del Part Studio pulsando sobre el icono del cronómetro ("Show regeneration times") en la parte superior del gestor de operaciones.
Once we have splines in drawings, maybe you could add a local section view?? ;-)
Thanks for the webinar presentation! Just a few more questions:
To recap: would I be correct in saying that in order to have elements of one configuration table drive those in another, I must incorporate variables in the feature tree that link the two tables?
Is there any built-in functionality between configurations and drawing parameters (e.g. titles, customizable fields, etc.)?
https://cad.onshape.com/documents/fba67f881283a5243aee4cd6/w/917776198c72b06946afef77/e/b9b251ffc6ea54c0d596a0d3
You can use configs to drive part properties which in turn can be displayed in a drawing. Hope this helps!
I edited this cell 3 times just to enjoy the effect
Something BOM related would be nice.
Blog Update:
https://www.onshape.com/cad-blog/introducing-design-data-management-2.0
Live Presentation (starts at 37:00):
https://livestream.com/accounts/25929353/events/8118439/videos/171991846
