Can Revision Numbers be set using FeatureScript?
MBartlett21
Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
Can Revision numbers be set using FeatureScript?
I want to quickly set all the revision numbers in a part studio at a time. I don't want to go through all 36 parts one at a time, changing the revision numbers.
Owen S
I'll just go with your way for the moment.
So, would there be any way to evaluate the revision number in a part studio only when the part studio is rebuilt for a release? I guess I should first ask... when I release a part, is it re-built one final time when I create or approve the release candidate? If so, I'd be happy to have a feature that embosses the part number and a placeholder for the rev level (similar to how its done in drawings), and then when the part is released, the rev number is added at that point.
Any of this possible?
