Reset Name of part
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
edited March 2018 in FeatureScript
How do I reset the name of a part so that I can configure it using featurescript?
EDIT: Also reset any of the other properties.
    did you tried setProperty() with PropertyType.NAME?
    edited March 2018
    @konstantin_shiriazdanov
     Yes, I did, but since I had already set the name, it didn't work
    edited March 2018
    Maybe someone from Onshape has a way. Maybe @lougallo or @NeilCooke
    jelte_steur814jelte_steur814 Member Posts: 78 PRO
    This question is still relevant: @NeilCooke or @lougallo? is there a way to reset (even manually to a default OS partname having once renamed the part?
    my current terrible work around is to supress the feature that initially creates the part, remake it in a new feature and then work through the whole feature tree to update all the references. only then i remove the original feature and can i use the 'partname featurescript'
    kind regards
    Jelte
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,417
    @jelte_steur814 - you're going to kick yourself....
    hahaa indeed! :#  thank you!
