Simple shape (in concept) - Y adapter
alex_wiebe
Member Posts: 4 ✭
I'm starting to really like OnShape - have designed a number of boxes, basic pieces. Now I'm stumped again on a fairly simple idea to conceptualize: Y shaped hose adapter.
I made a hose adapter using the loft tool to change from one shape (square) to another (round) - but in this case I'm not changing shape, but rather diverging or splitting a extrusion.
I'm thinking I start by sketching the base tube, then create a couple offset planes on angles up top and sketch the same tube profile.
But now how to extrude up a distance, and then split into 2 extrusions that meet the lofted planes?
Or am I completely thinking wrong.
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
Try this.- Start by creating a simple extruded cylinder.
- Offset a surface from the end of the cylinder and sketch another circular profile but offset to the side by a little more than half the diameter (symmetry line shouldn't tough the circle).
- Loft from the end of the straight cylinder to your 2nd circular sketch. Make sure you're using the New option and that the start/end condition is Normal to Profile.
- Mirror the loft body using the Add option and make sure the merge scope includes both the straight tube and the lofted tube.
- Shell the hole thing and select the three flat end faces for removal.
5
https://cad.onshape.com/documents/2be09e87958bc03983b7512b/w/8d417b0b7b149c74c83b9308/e/0b4cd91cbbdc0305cc532406
I don't actually want the loft to curve, so I've left the ends to default.
But I do want the top ends to be perpendicular to the tubes and not parallel to the bottom. So on to the next learning curve!
