Problems with the software
lancelotlancelot OS Professional Posts: 3 PRO
Hi,
I have some problems with the software, there is a lot of connexion problems and I can see that I am 4 times in the same project.
Do you have some issues with your servers?
    @Lancelot Can you use the Feedback to to send in issues with your experience on connectivity?  It would be more helpful if we knew some specifics, which you probably don't want to share here.  Go to the ? menu and select feedback.  I will create a ticket for you now.  ~Lou
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 407
    HI @Lancelot. We are not seeing any problems with the servers at this point. Can you please open a support ticket by clicking on "Feedback" under the "?" menu in the product? Sorry for the hassle.
