Konvert surface to part
Kai_himselfKai_himself Member Posts: 45 ✭✭
Hey,
for simscale i need a geometry without wallwidth. I have a modell with only surface areas. I cant import this into simscale. I it possible to convert the surfacemodel into a part model ? Here is the link https://cad.onshape.com/documents/e5594902445e99fc5ccdd37a/w/e5d72114dfcb339596413de0/e/d04f4890131385516d6e2bc5
Greetz Kai
    edited March 2018
  • Kai_himselfKai_himself Member Posts: 45 ✭✭
    Hey @Jake_Rosenfeld ,
    thank you for your answer, but the modelwalls has do be zero thickness :(.
    Greetz Kai
    Hey its me again,
    know anyone why i cant import my model to simscale ? I made a picture from it.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,859
    First of all I would consider contacting simscale support. They are the author of the Onshape connector and may have a better idea of what is happening. If you want just surfaces you could export your Onshape model in STEP format and upload that to simscale.
    I actually find it easier just to export models and import into Simscale rather than using their connector.
    Hey @NeilCooke and @brucebartlett ,
    thank you for your answers.
    I try it in the STEP format, but i cant import it into simscale. Than i try it in stl format, that works, but i dont have only one geometry without single surface, that is bad, i need single surface to assign boundary conditions.
    I wrote an email to the simscale support, i will get back to you.
    Greetz Kai
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 219
    Hi, @Kai_himself
    I am confused why you are looking just for surfaces. Managing disjointed surfaces for any simulation ends up kind of being a hassle.
    My go to method for Simscale is actually to import the volume I am interested in and create topological entity sets off the solid object. This allows me to create interior walls and inlet and outlet lids on the surfaces of the solid part.
    Then you can create meshes from those topological entity sets later. My image only shows my mesh creation for the walls of the converging-diverging nozzle.
    Then you can later define the whether the meshes are walls, pressure or velocity inlets/outlets.
    Simscale support is super helpful and their videos and papers are very informative and get you to the right information quickly. The key is to make sure all of the dots are either green or blue, no red ones.
    https://www.simscale.com/tutorials/
    https://www.simscale.com/docs/
    https://www.simscale.com/learning/tutorials/
    Thanks!
    Jason
    Support & QA
    @Jason_S,
    thank you for your post !
    I will try it with the topological entity sets. At my first try, i creat the geometry with parts. I have a picture that shows the problem.
    After the Mesh i got a internal and a external wall, at a surface i got only one wall.
    Maybe i can avoid it with topological entitys.
    Greetz Kai
