Revolute Mate
Could anyone give a little advice please, I am designing a spiral staircase round a centre post. I have positioned my first tread which I have fixed and
the next tread is attached using a revolute mate in order to position it in the correct position above. I would now like to remove all degrees of freedom. At the the moment I have used fixed for this purpose. Can anyone say if there is a different way to do this as somehow this doesn't seem correct although it works. Regards Brian.
Twitter: @bradleysauln
and @lemon1324 got it 100% right.
Define 2 mate connectors for each step. One is at the origin, the other will be projected straight up and rotated appropriately.
now it's just a quick fastened mate for each step.
I usually do a few steps (about 90 degrees worth), then copy and paste that group, then mate that larger group.. etc.. should only take a few seconds to mate up a large spiral with this method.
You really want to stay away from hand editing every mate in an assembly. Take advantage of part studio mate connector for these repetitive tasks.
And hope and pray they release more pattern options in assemblies
This would be very useful.
I did not know about this before.
Best wishes & have a good day to all. Brian.
Sounds like it's time for a featurescript.
Inputs of number of steps, degrees of rotation per step, and height of step.
Not to make the steps (duplicate part instances) but at least to make the mate connectors?
but too bad we cant just FS in assemblies, so that is still manual
https://cad.onshape.com/documents/d66ea5fec7a939e866ecbd6f/w/25d8c7ecb4fba2c4e6eb34a4/e/da105d925bece61b58a66bef
