Almost beyond the system limit...
in General
I did this model that was almost at the system limit.
If I made it any bigger, it didn't work.
The arcs and circles are all showing up wrong.
Why would this be happening?
mb - draughtsman - also FS author: View FeatureScripts
Wow! One of our active priorities now (and pretty much always) is improving the fidelity of our tessellation. Your example looks like it could be a really good test case for us. Please make a version on your document that shows the issue and share it with us using the "Feedback" button under the "?" menu.
Sorry you're experiencing this.
Here is the document: https://cad.onshape.com/documents/6320c1fa97928fa83a4cdaf5/v/de570ed25c578ffa4dc457b2/
I have done the grey part on the right corner.
For some reason, the report a bug function isn't working. Does it need a website whitelisted??
When I try to report a bug, nothing happens, even when I click the button again.
I do have an internet filter on, would that be stopping it working?
That's going to need one hell of a press break
There are only so many numbers that can be represented in floating point format. When your number is close to 0, the resolution from one floating point number to the next is very very very fine. When you're out in the boonies of the real-number line there may be noticeable gaps from one number to the next. So, the tessellation may be inexact in the first place (because of the inability to exactly represent the number we want) and then the issue compounds through a series of mathematical operations on your graphics card. This is why the lines of the model seems to jump around; as you rotate the part you're seeing hops from one to the next discrete solution of a floating point operation.
In any case, your part looks fine if its translated closer to the origin. Test cases are always welcome though! Submit that ticket if you got the feedback tool working, otherwise let us know if that's still being stubborn.
@Jake_Rosenfeld
I was just having fun.
I also made a feature in that document which adds bend allowance to the sheet metal model.
I would find this very useful if you could specify the bend allowance per bend
