Constraint Disappearance
jon_woellhafjon_woellhaf Member Posts: 92 ✭✭✭
In a Sketch, if a line is drawn to the bottom or right of the sketch area, the constraint indicator disappears off screen.
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,912 PRO
    Can you give a screen shot? I don't know what you mean, I can't replicate what I think you mean :)
    Please see the brief video I made at https://www.youtube.com/watch?v=fpsjEgNAfS8
    oh, it's while you're placing the line. got it.
    You will have to put in an improvement request to have that one changed :)
    Otherwise I'd say there is no need to sketch that close to the screen edge anyway.
    Draw your sketch relative to your screen area, then your first dimension will scale the entire sketch to the actual size.
    Or zoom out with your scroll wheel a little if you need your line longer than your screen area.
