cannot snap to origin in sketch mode
alex_lototzkyalex_lototzky Member Posts: 5
I am creating a second sketch in a part, but I want to create a construction line from the origin but cannot snap to the origin!
I also cannot move the coordinates of the line to coincide with the origin after creating the line.
What am I doing wrong
also: I see that "s" is the shortcut to snaping. If this is a toggle function, where do I see if snap is on or not
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    This should be possible (see GIF below). Feel free to file a feedback ticket if you think you are seeing a bug.
    Twitter: @bradleysauln
  • kristoffer_palanderkristoffer_palander Member Posts: 1
    Hi, I have problems snap line or rectangle to the orgin? I either get a horisontal or vertical constrain?
