where can I find the setting of quantity holes?
dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,977 PRO
    You will have to count manually and enter it into the hole dialog box while placing your hole callout
  • dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
    My mean is get quantity by itself.Deon't enter it.
    Automatic hole count doesn't exist yet
    When will this function???
    @dragon_chen_dragon
    Make an improvement request in the category at the right >>>
    I'll vote
    Same here
  • 3Dsculptor3Dsculptor Member Posts: 2
    Is this thing really still missing? I tried to find also a way to show hole instance count in the callout but could not find a setting for that…
    Should be quite elementary to have it for hole callouts.
    Another powerful callout would be for pocket radii and circular remove extrusions - hole callout would be smart enough to tell, if a pocket radius is up to a depth or circular hole is THRU….
  • jelte_steur814jelte_steur814 Member Posts: 530 PRO
    edited March 13
    @3Dsculptor :
    when you use the hole callout table, the quantity is added automatically. That would be recommended.
    for a particular hole call-out the arrow suggests you mean that particular one, so counting automatically would add unlogical numbers there…
    Circular removed extrusions can be called out automatically if you tag them in your model using the custom feature discussed below:
  • odyody Member Posts: 4
    "[…] counting automatically would add unlogical numbers there…"
    Displaying count for repetitive features is well documented in ASME Y14.5 and widely used.
    It's more confusing if the count is not displayed, or worse, if the edit is done manually—-current workaround—and then goes out of sync with model changes.
    How come this is not yet available?
    ah I see. the current table just counts all holes with the same spec. in this case the hole count would be dependent on a pattern-feature?
