Extruding dilemma
David_LaPoint
Member Posts: 10 ✭
There must be some rule that's preventing me from extruding this last 'wall'.I can click on all the other exterior walls and get surface extrusions, but if I click on this last one it fails and removes two others as well. Furthermore, if I try to also extrude the interior walls, it also fails the exterior walls.
https://cad.onshape.com/documents/e33aaab38a4ae22f0c9b299d/w/805e1657ff7d75b0b44c92b3/e/c6852f20460a93dac4eb4fca
r walls and get surface extrusions, but if I click on this last one it fails and removes two others as well. Furthermore, if I try to also extrude the interior walls, it also fails the exterior walls.https://cad.onshape.com/documents/e33aaab38a4ae22f0c9b299d/w/805e1657ff7d75b0b44c92b3/e/c6852f20460a93dac4eb4fca
john_mcclary
Member, Developers Posts: 4,055 PRO
Something is wierd about that line.. even when you only extrude that line it fails.
I was able to get it to work by deleting the line and re-inserting it
5
