I am stuck in "Exersize: Creating multiple parts in a part studio"
Choboko
Member Posts: 8 ✭
I am doing something wrong. For some reason the newly extruded grip of the large arm will not become a part but add itself to the Larm Arm, but the small grip will.
Question: I like to know what I did wrong in the proces and came apparant at slide 13 of 24?
Jake_Rosenfeld
Seems like a great project @Choboko !
If you think you've accidentally deleted a document, you can check in the "Trash" on the left hand side of your documents page.Jake Rosenfeld - Modeling Team5 -
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
All fixed up. I adjusted the sweep profile to go inside the hub a little. I also changed the sweep and thicken from Add to New and spiffed up the filleting scheme a bit.
https://cad.onshape.com/documents/3a246dfdbeead17d4e680cad/w/9261d6e1e5846915e62e7c0d/e/724ebd020bf6a81065265454
6 -
KatieHuffman
Member, Onshape Employees, Developers Posts: 194
@Choboko
Your image of the clamp exercise looks correct at first glance. You can restore your document from the trash. Just navigate to the trash on the main document page (on the left), right-click on the document and select restore. It will be there as long as it hasn't been in the trash for more than 30 days. If you want to share your document with me once you restore, I will take a look, khuffman@onshape.com. You also can access the completed document from the self-check question.6 -
Jake_Rosenfeld
Hi @Choboko
Try this:- Delete "Extrude 5" and "Extrude 6" (clean slate)
- Hide "Master sketch"
- Try creating "Extrude 5" again as shown in the instructions
Edit: To hide "Master sketch" hover over it in the feature list and click on the eye icon that appears next to it.Jake Rosenfeld - Modeling Team5 -
Jake_Rosenfeld
@Choboko
You are right though that for some reason "Extrude 5" the way you have it now is both creating new parts AND adding to the large arm with "New" selected. This seems like a bug to me, I'll create a ticket for its investigation.
Looked into this. As expected "Extrude 5" is created all new parts, but the use of "Add" in "Extrude 6" was making the grip and large arm join each other.Jake Rosenfeld - Modeling Team5
It will be easier to diagnose if you post the URL of your document here so others can look at it directly.
It is the first real document I made myself in onshape. I has a small error in the helix somewhere and for some reason & I can not boolean the axle and the blades yet (hopefully I can end up with 2 parts, frame and an impeller in 1 document), but I will figure it out tommorow hopefully. I am pleased with my progres so far, the document looks descent for a first design. My goal is to make dummy-computerparts that i can use to design pc-cases with/around, top-down in onshape. So I am making lightweight documentlibrary of pc-part designs like powersupplies, fans, motherboards, graphiccards etcetc, that was my initial idea. This way I can simulate a real factory-engineering-environment (although very simplistic) and I challenge myself to use commands in the partstudio that I normally would not use. What I remember from solid works and solid edge from 10 years ago, was that structure is important in parts, assemblies and how you manage and structure data. So with this dummylibrary approach, I try force myself to think about data-structur, structure in parts and for example labels in such a way that my dummy parts can be used in every new case that I will design in Onshape in the future.
Thanks again for replying to my thread!
https://cad.onshape.com/documents/3cdba40e2c55421151504635/w/381464e2dfad808e9f7dab40/e/d61c2ca9495cd59b718e3215
Thanks again!
Dumbledore is that you?
Thanks to all you for the advice about restoring the document.
The selection assignment v.s. my selection.
As you can see, I can not for some reason select the same surfaces as step13 describes. It is likely that this has something to do with my problem that the large arm clamp does not get assigned it's own part but remains in the large arm part. So I probably made a sketch or a selection mistake in an earlier step, to deserve this punishment.
Try this:
It looks like the master sketch is just getting in the way of the other sketches here, so you can't select the desired sketch regions.Edit: To hide "Master sketch" hover over it in the feature list and click on the eye icon that appears next to it.
Thank you for your help, it worked! I have two separate parts now. I had/took two/three weeks off and now I am picking up the pace again.
I have been trying to figure out why your fillets on the fan are great (and mine are not), but haven't been succesfull at figuring it out why mine suck. I saw you altered my "sketch 8" regarding the fanblade-sweep in your model, i tried to do the same but am i still getting a wrong fillet. What am I not understanding well enough to create to same sleek fillets you do?
If you see time answering my question, thanks.
It's a bit complicated to explain every step. I suggest using the rollback bar to look at my feature tree starting with Sketch 8, the sweep profile. Notice I extended the profile line so that it goes past the center cylinder. That way when you create the blade with a thickened sweep the two bodies overlap each other and can be merged more easily. It also makes for better filleting. Also pay attention to when I selected New vs Add as well as the order of fillets and other features.
