For feature script can you have items with different sequences under the same profile?
We use 1" x 1" square tubing to do custom fabs at work so I created a profile to add that size to a beam feature script. Only problem is that the sequence it gives me is:
"LALALALA-LALALALA"
I was able to put it under the standard ANSI inch still but had to create a separate profile as the sequence does not match those under square tube which is:
"LALALALA-ALALALAL"
What could be the reason for the switching of the line and arc inputs in the second part of the sequence? I know it is the same for square tube and rectangular tube so I'm not sure why it is giving me this. Thanks for you help ahead of time, I have already learned a great deal through this forum.
"LALALALA-LALALALA"
"LALALALA-ALALALAL"
NeilCooke Moderator, Onshape Employees Posts: 5,848
The sequence is generated by the sketch entity creation order. If the profiles are made from the same (modified) sketch the sequence should be the same. If they are separate sketches there is no guarantee.Senior Director, Technical Services, EMEA5
