Attach Text to BOM Balloon
S_Regula
Member Posts: 95 PRO
There are instances where a note is needed for a part (i.e. a quantity callout or a special instruction needed at the time of assembly). If a note could be added to the BOM balloon, it would eliminate the need to add a separate note (with leader). This would help keep the drawing clean and easy to read.
You can do this.
When you insert your balloon, you can set whatever you want to display on the balloon
In your case you might want to select a Tight fit condition on the border size, OR... just pick the option for none on the border shape.
And by all means add as much text to the callout as you like. There are prefix, suffix, fields above and fields below the center field.
Once you have changed the style of your callout, we will remember the last state of the dialog for each new time you use the tool within that drawing.
Edit the content before you click to place it
@EricGauthier
I am having trouble getting Callout Balloons to show Custom Properties for different configurations of a part on a drawing sheet. The process for successfully getting custom properties to show (and not the little red dashes) is hard to understand...and, I think, inconsistent. Unless the rules for how to use Balloons are much more complex than I realize.
Has anyone had luck with using Balloons for different configurations on a drawing? Anything like "you can't have balloons with links to more than one configuration on a drawing" or something?
Thanks!
Make sure the balloon is attached to an edge, not a face
That doesn't seem to help in my case. I feel like there's either something wrong with my drawing / part, or I'm trying to do something that OS is limiting or unable to do for now.
Can you give a little more detail on what you are seeing or post a link to your document please? In the image below I have a trivial case of two different configurations of the same part on the same drawing, and I have attached a balloon containing the custom property 'Custom String'.
Will see if I can post more specifics sometime soon.
Romeo
Please notice that In Boolean Union and Intersection operations the identity of the first selected body survives.
If this does not help, please contact support via "?" menu and share your document with support. We'll try to help you.
