How do I use skConstraint?
MBartlett21
Member, OS Professional, Developers Posts: 2,034 EDU
How do I input elements?
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,402use "externalFirst" : querySenior Director, Technical Services, EMEAI5
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,402From "show code":
skConstraint(sketch, "c99949d7-ddbc-4a09-93e3-94938c1de6f8", { "constraintType" : ConstraintType.TANGENT, "externalFirst" : qUnion([ExWqaqjQPdYcPt_query]), "localSecond" : "8jPV4RCM-F1f6-lszt-84PG-uKZL1O4AJyqe" });
I would like to add a constraint to an entity that is not in the sketch
How would I do that?
I tried using "Projected", but I don't know what parameter should be the query
