Flat pattern from convert
Having some trouble creating a sheet metal model for my part. I realize some features won't be possible so I excluded the faces of them.
Model is here:
https://cad.onshape.com/documents/a71bc4365dae58b5c767636e/w/d7917624a78333e84709a4ea/e/262b54fa3622521777020b6d
Model is here:
Can you recreate the failing sheet metal model feature and commit it using the green check mark? It would be helpful to see which faces you're trying to include/exclude.
