Flat pattern from convert
bill_de_la_vegabill_de_la_vega Member Posts: 20 EDU
Having some trouble creating a sheet metal model for my part.  I realize some features won't be possible so I excluded the faces of them.
Model is here:
https://cad.onshape.com/documents/a71bc4365dae58b5c767636e/w/d7917624a78333e84709a4ea/e/262b54fa3622521777020b6d
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Can you make the doc public? Link is view only.
  • bill_de_la_vegabill_de_la_vega Member Posts: 20 EDU
    Should be public now.
    edited April 2018
    @bill_de_la_vega
    Can you recreate the failing sheet metal model feature and commit it using the green check mark?  It would be helpful to see which faces you're trying to include/exclude.
  • lanalana Onshape Employees Posts: 746 image
    This model looks like better suited for Thicken option then Convert
    Ok, I just did that.  I also labeled the features somewhat arbitrarily since I don't have the mechanism that this goes into yet.
    Thanks, I'll have to look at that thicken option more carefully.
