I would like know.Is there remember last time function?Is there have parameter function?
dragon_chen_dragon
Member Posts: 22 ✭✭
There is no functionality in Onshape that can show previously used values for a specific parameter. If you would like to see this as a general tool, or as the default for a specific feature, please open an Improvement Request from the Improvement Requests section of this forum.
There is parameter function, in Onshape they are called variables. Hit (x) to add new variable then write #variable_name to dimension dialog.
https://cad.onshape.com/help/#variable.htm
