Help with simple sheet metal needed
rachel_arden
Member Posts: 14 ✭✭
So I'm working my way through the sheet metal help, and videos and thought while I did I would post my problem up here.
I've not worked with sheet metal models in any cad package and need a simple part which has a bit in the middle bent up.
This is the desired shape (sans bends):
https://cad.onshape.com/documents/0aa40800cd63f8ebf857817b/w/7673badb56f6f93ed6ee1633/e/c46e994431ad1a187016ff36
Try as I might with the sheet metal model tool I cannot work out a way to convert this into an actual sheet metal part.
The important details are the bit in the middle must be 10mm across, and the inner bend needs have a 2mm rad or less.
I know I need gaps around the cuts but dont know to add them, do I have to put in an approximate cut before I try and convert it?
Please help, I know there must be a straightforward way to do this but I just don't know enough about sheet metal, onshape or otherwise, to see it.
NeilCooke
Moderator, Onshape Employees Posts: 5,938
Draw the flat portion with the cutout area, create sheet metal model using thicken, then use the flange tool on the cutout area. There are other ways, but that is probably the quickest.Senior Director, Technical Services, EMEA5 -
NeilCooke
It's probably your sheet metal model settings - see my model here: https://cad.onshape.com/documents/ffe1994c53dc87fb2130e691/w/13063414daed68dc087c778c/e/0da5718bcbc0d6f30fa762e7
(and no, you should not ignore the warning!
Jake_Rosenfeld
Also it looks like your "Bend relief type" in the "Sheet metal model" feature may be set to "Tear". You'll want to change it to rectangle or obround to get bend reliefs.Jake Rosenfeld - Modeling Team5
Sorry to be slow about this, but I really am at sheet metal 101 or a lower level of knowledge. I get you mean that it is technically correct in what the processes are telling it to do, but it's still not giving me the correct model I need; what I need for it to be correct it a working sheet metal model and flat pattern I can send off to be made. So I need the bend (which I know have, thanks to you!) and I need a gap to punch or laser cut the sides of the flange, since this needs to manufactured by one of those methods.
How do I get a gap on the model? This goes back to the top query, do I add the gaps in before converting the model to sheet metal or is there a tool to do it automatically? The bend relief tool, from what the help says, seems to be about editing bend relief already in there, so how do I put on in? (Or alternatively, what do I select with the tool to get it too work, as I've tried the inside edges of the flat bit, the outside edges of the cut out)
That's the expected behavior of doing a flange on that edge. The easiest way to correct the situation is to do that flange and then use the "Move face" feature on the two side faces of that flange, moving them in by whatever small offset you desire.
