Importing CATIA Files
tom_helsley
Member Posts: 4 ✭
I just tried importing some CATIA V5 files. While the .CATPart files worked fine, the .CATProduct files didn't. Are there plans to support importing .CATProduct files in the future.
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
@Tom_Helsley Most assembly files we currently do not support only since they are typically containers for parts. The only assembly file we are supporting through their Pack and Go tool is SolidWorks. In most cases the best option is to export as STEP, ACIS or Parasolid and import that. Since features are not imported, an export of the assembly is the current the best way to do it.
In many of the assembly file formats, the approach will probably continue to be performed with an export format since the native formats require the OEM's engine to find the external references.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
