Spline constraints
Edward_GoodwinEdward_Goodwin Member Posts: 25 PRO
I'm looking to constrain splines within a drawing. I can't work out how to constrain the direction/length of the spline handle... Any tips?
Also, it appears that there are no spline handles for points except for the start and end points. Is that really true? How do I manipulate the length/angle of a curve within the spline? Surely this can't be the case otherwise it seems to me that splines are severely limited in comparison to other cad packages.
Al thoughts and (I hope) solutions gratefully received!
  • Edward_GoodwinEdward_Goodwin Member Posts: 25 PRO
    Thanks Neil. This is a useful little animation you've added. It's frustrating that it's not possible to do this in one spline as I need to create something which is effectively a wavy pattern over a non-symmetrical surface (hence I can't actually pattern a spline/curve). It means I'll need to create hundreds of individual splines and connect them together whereas in SW I could have done it with 12 and then simply constrained the handles... Hey ho. I'll make the feature request.
  • colin_king506colin_king506 Member Posts: 58 ✭✭
    Good to know. Getting to using splines more in a model and this fits the bill. TY Neil.
