How can I spread N points over a spline at equal distances?
I know how to spread N points over a line (using the distance tool). With an arc or a circle, I'd use the polygon tool.
But how would I do the same with a spline?
LearnOnshape facebook group
@Ben: If I understand your idea correctly, I would create six lines, each end point on the spline (coincident), then give them all "equal length" and then move the endpoint of the first line until the endpoint of the last line is at the end of the spline?
That would work in my case since the curvature of the spline doesn't change too much, thanks.
However, for cases where curvature was too curvy for this to be useful, I considered a reasonably simple approach:
You are currently able to create a string of 2-point splines, setting a tangency constraint at each junction between adjacent splines. This will behave like a single multi-point spline.
Unfortunately the next step, setting the length of all the splines to be equal, is not yet implemented.
It only works for lines and curves (by which I presume OnS mean circular arcs)
- Placing chairs around a meeting table or along the ranks of an amphitheater
- Place columns to support a roof
- Pylons around a park or along a bridge
- Creating star-shaped designs with irregular outlines
Currently dimension is made horizontal, vertical or angled between points, dimension is always straight line between points. It would be great to have option to dimension for example spline points along the spline.
Here's a frankly boggling demonstration:
The shifting baseline of human expectation sometimes causes me a wry smile.
"A useful option every now and then" is, I think, a fair assessment of this particular functionality ... meaning that the benefit, rationally assessed, is disproportionately small in comparison to the difficulty of solving it ... and yet in a few years the capability will be considered trivial and 'entry level' !
(This is not aimed at you, 3dcad, but at the human species!) I'm reminded of a princess from a fable, casually directing a prospective marriage partner to provide her with an item life-threatening to attain. An item, it turns out, which she's not exactly certain she will enjoy or even use.
