can I take a jpg or similar view of the current part studio?
simon_9
Member Posts: 17 ✭✭
I want to illustrate a description with some views taken from several angles of a project - is it possible to 'snapshot' those views since screenshots require more editing effort to clean them up?
Regards,
Simon
Regards,
Simon
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
Select 'Print' from Document menu (hamburger), set paper, click Print. It will open new window with image which you can RMB click and save image as png.
Image will be like screenshot but much better quality so prepare planes and other references hidden if you like.//rami7
You ought to be on the Help documentation team!
Does your system print dialog open up when you do this? If so, most browsers/operating systems/printer drivers will allow you to choose "Save as PDF..." or something similar when choosing a printer.
