Rotating features in a circular pattern
BTWaidBTWaid Member Posts: 13 PRO
I am trying to rotate features about a line in a circular pattern but it is not working.  When I choose the line for the axis to rotate the features, the description for the line is changed to "edge of sketch" and the rotation does not work.  What defines an axis and can I create one for rotation?
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    edited May 2018
    Hi @mitchell_machelski. Welcome to Onshape. Check out the Forum Post Checklist. Specifically, try posting a link to your document. Otherwise, trying to explain your question just looks like a lot of verbal hand-waving that probably won't get many answers if any. But if you post a link, I and many others on the forum will jump through hoops to fix your problem. We're handy like that ;)
  • BTWaidBTWaid Member Posts: 13 PRO
    http://https//cad.onshape.com/documents/4dfc03bde071cfb9cc6e8068/w/67624c4cfc75d67ef02a886e/e/6be53bec1d8ae9dd33d8c140
    Here's link. The slot on the outer diameter is what I am trying to rotate on a circular pattern.  I've done it before with success.
    @mitchell_machelski link is not working.  Check that it is correct and public
    www.accuratepattern.com
    I forgot to make it public.
    @mitchell_machelski
    Can you leave the failing circular pattern in your document?  I'm looking at your document and your sketch line should be fine as an axis, but I'm not sure what you are trying to rotate, and what you mean by failing.  Does it create unexpected geometry or is the feature actually red?
    Okay I did...
    Link still isn't working, though. Likely only OS employees can see.
    @mahir
    The link is public but it's sort of messed up up there ^.  You'll notice it says http twice.  This should work:
    https://cad.onshape.com/documents/4dfc03bde071cfb9cc6e8068/w/67624c4cfc75d67ef02a886e/e/6be53bec1d8ae9dd33d8c140
    edited May 2018
    @mitchell_machelski I would try a face pattern instead of a feature pattern. Feature patterns are tricky. They're great in theory, but there are some important downsides. First, since you're patterning the features, you have to also pattern any reference geometry that would be required by the patterned features (planes, etc). Feature patterns also take longer to rebuild. If you have a complicated set of features that need to be replicated exactly (like on a flat even surface) with no modification, face pattern would be a better option. Alternatively, if your feature is the result of a Boolean, then try a part pattern followed by a Boolean on all the patterned bodies.
    @mitchell_machelski
    As stated in the error message (accessed by hovering your mouse over the feature name), you need to select "apply per instance":
    Ah, and then there's "apply per instance". I forgot OS just added that option this week :) This in effect makes your feature pattern a face pattern, but without the inconvenience of selecting individual faces.
    Thank you!!!!
    @mahir
    Just to clear things up:
    Having "apply by instance" off something similar to a face pattern using feature selections.
    Having "apply by instance" on does the old behavior of feature pattern (re-executes the features in the selection for every pattern instance).
    @Jake_Rosenfeld, gotcha. I forgot a "not" somewhere in there :)
