Mirrored Sheet metal
Mathieu_Guilmette
Member Posts: 12 ✭
I mirrored my sheet model but I want it to create a new entity because
they are not cut in the same sheet metal. One is for the left side and
the other for the side so some bends are not the same. Is there a way
for the mirrored part to become its own sheet metal model?
Optionslana Onshape Employees Posts: 700You can not split sheet metal models currently. You can use sheet metal table to change bend radius of individual bends.
https://cad.onshape.com/documents/4a079f05c8c5469816224cb4/w/3f7cbdc5408b24c152dd7591/e/ba3591ffe3a02870234643f4
5
That sounds reasonable - please create the IR.
