How to add a part length to a part name
david_goughdavid_gough Member Posts: 5 PRO
I often use extruded aluminium lengths to build machine enclosures for customers, and when I have finished the design I export the model as a Parasolid.
When designing the model the length of each extrusion is defined by a Configuration variable.
My clients need to have the length of each extrusion in the part name so that they know what to order, for example, “Alprofil 40 x 40 Light L1000”, where L1000 is the length in mm. Is there any way to append L1000 automatically to the Part Name?
I appreciate that this will have to be done using FeatureScript and would appreciate any help.
Thank you.
  • david_goughdavid_gough Member Posts: 5 PRO
    Thanks. It is from an actual variable so I will see what arrives to do it in the future.
    David - here is a simple example of how to do this :)
    https://cad.onshape.com/documents/61e112bec493ae9f0cdd1eef/w/422f340a0bd2767715b1fc6e/e/4e59cdbeeaf56dc6b10245a3
    annotation { "Feature Type Name" : "NAME OF FEATURE", "Feature Name Template" : "Feature Tree Name (#volume)" }
    export const hoseBead = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Pick a Part", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
            definition.myPart is Query;
            var partVolume = evVolume(context, {
                    "entities" : definition.myPart
            setFeatureComputedParameter(context, id, {
                        "name" : "volume",
                        "value" : partVolume
    Philip Thomas - Onshape
    Hi @philip_thomas, nice feature.
    I believe were after a length for a cutting list here.  Is there any way to extract a length from a part?
    Cheers,
    And insert it to part NAME so that it's defaulted on export name too..
    Excellent, thanks for all the help, I will give it a go  :)
    edited May 2018
    @philip_thomas  Good point Sir, hadn't thought of that.  The same method sounds really useful in the beams FS too.
    Thanks for the nudge,
  • stuart_wood540stuart_wood540 Member Posts: 6 PRO
    @owen_sparks - did you get anywhere with this for ‘Beams’ ? I’m completely new to OnShape ( from Inventor ) and this would really be useful as a stopgap measure for pipe lengths while I get my head around the new ways of working.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    Make sure you are using the correct up to date version of Beams. It will add the length for each beam in the part name and show a cut list in the custom table icon on the right.
    I didn't follow it up Stuart but following Neil's comment I will check it out as it seems to be solved. By the way I came from SolidWorks and love Onshape so much more.
    @NeilCooke I have FeatureScript Beams official v16 and I don't get the beam length showing. Any ideas would be appreciated  ?
    Many thanks.
    I removed the length from the feature because it does not take into account beams that have been manually trimmed afterwards. Open the custom table icon on the right to see the cut lengths.
