How to move files to another account
steve_cartersteve_carter Member Posts: 8
For a while I've been making models/drawings for somebody else as they were not particularly cad literate. Now they are starting to learn,with my help, and have there own account here in onShape. I would like to transfer all of everything I drew for them over to their account. How do I do that? I've looked at import export files and it doesn't seem to be want I need. Both accounts are hobbyist
Thanks
  • steve_cartersteve_carter Member Posts: 8
    Ok I'll try that, thanks.
    That worked OK, the entire folder and sub folders/files. How do I change the ownership?
    OK I have all that done, friend in now the new owner. How can I remove all the files from my account with out affecting my friends? I delete a drawing from my account after the ownership was transferred and it remove the file from his account as well
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,922 image
    Right click and select remove me from share
  • matthew_hill679matthew_hill679 Member Posts: 3 EDU
    "Owner" is not one of the options. Is that because I am trying to share from an educational account to a non-professional account?
    That’s because that screenshot is 4 years old. To do it now, right-click the doc on the docs page and “transfer ownership”
    Hi. Is there a way to share an entire folder rather than sharing documents individually? Thanks.
