Measuring parts rather slow
dan_engererdan_engerer Member Posts: 63 PRO
Hi. Just some general feedback here. In Onshape, when you select a line or two planes, etc. to measure, it often takes 5+ seconds for the measurement to show up in the lower RH corner. Shouldn't take that long. Thanks.
    @dan_engerer - should only take a fraction of a second (just tested it).
    How is the performance in other areas when this is taking 5+ seconds?
    Please hit Ctrl-D to bring up the performance panel - what is your ping time (steady state, not doing anything)?
    Philip Thomas - Onshape
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    PS are generally pretty good but I find assembly terrible after first loading, 5+ second sound like what I will be seeing frequently, which I can accept on big assemblies on loading but sometime I click and click and click then refresh the whole browser just to get a measurement from an assembly.
  • robert_morrisrobert_morris OS Professional, Developers Posts: 170 PRO
    I will get this occasionally as well.
    It will take a while to show up and sometimes will only show the result of one of the mouse clicks. For example, I will click on two faces to get the distance and after a few seconds it will just show me the area of one face.
  • dan_engererdan_engerer Member Posts: 63 PRO
    The above 2 comments are exactly my experience as well.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    edited May 2018
    It depends on what is in your assembly, I've had some assemblies take over 2 minutes to allow me to measure, and it was only calculating the first input, so I had to un-select the second point, then wait for it to calculate again, then select the second point, wait more. (once the document slows down like this all bets are off though.. internal errors are corrupting something, hoping a few updates address all the sheet-metal performance issues)
    It feels to me like it is rebuilding the entire chain of part studios/assemblies before giving an output, rather than just fixed points in the current 3D space. This happens more often with sheet-metal
  • malay_kumarmalay_kumar Onshape Employees, Developers Posts: 93
    Thanks for this discussion. We are actively working on performance and would like these performance issues to be improved. Can 1-2 of you guys report reproducible cases of this through feedback tool and share the model? We are aware of few inefficiencies for example first measurement on any part in assembly will be slow, measurement involving configured parts will be slow. But slowness is relative so it will be nice to exactly understand what is going on in cases that you are running into.
    Already have over the last few weeks with lou, he has helped alot to get me thru my progects. But sheet metal definatly needs focus.
    edited May 2018
    Thanks for listening @malay_kumar, I'll try and make a report with a quick video next time I see this issue. The face issues mention above sounds familiar, I want a distance between 2 faces, or a face and a point in an assembly and all I can invoke is an area. Sometimes I just have to give up and get it is from a part studio or refresh and come back and have another go later, but it's hard to put my finger on why or when this happens.
    I too have experienced this. I didn't know if it was an OS issue, or my end.  Closing and re-opening the browser always fixes it for me.  Also whilst we on the subject exporting to STL sometimes doesn't do anything from an assembly but switching to the part studio always works.
    Cheers Owen S.
