ANSI Flange in the January 2nd "What's New" video about configuration?
AlexD
Member Posts: 17 PRO
Where can we find the ANSI Flange used at the end of the January 2nd "What's New" video about configurations:
https://forum.onshape.com/discussion/7975/improvements-to-onshape-january-2nd-2018/p1
THANKS
THANKS
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Thought I'd made that public - it is now. Although the sizes are based on the spec (from a supplier's website), it doesn't include every permutation. I used this as an example to see how far I could push configurations to be more like a configurator.
https://cad.onshape.com/documents/36d5314a70153cbd63de384f/w/ecc6d196a635c11c03cad1c8/e/880b4fac43003796ddcb1b97
Senior Director, Technical Services, EMEA7
Excellent example of pushing configuration. Impressed by using derived Flange in the elbow's configuration!
Good news, Onshape has automatic part numbering built-in already! If your organization has Release Management turned on, you can define part numbering schemes, and then assign part numbers from a release package, from the part properties of a part, or even from a BOM in an assembly.
Short video:
https://www.onshape.com/videos/release-management-and-approval-workflows
Webinar:
https://www.onshape.com/videos/introducing-release-management-and-approval-workflows-040518
